weed eater 15-inch cut
Lieutenant's Avatar
05-17-07, 10:54 AM   #1
Greetings to all,
what is the spark plug gap for this weed eater "Featherlite Fl20". Someone put oil in the tank, then put gas in the tank and tried to mix the mixture in the tank...How do I clean the system out...
cheese's Avatar
GA
05-17-07, 11:30 PM   #2
Gap the plug to .030". Dump the old mix out, refill with the proper mix, and push the primer several times. The primer will circulate the new fuel into the carb, and flush the old mix out.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
puey61's Avatar
NY
05-18-07, 02:54 AM   #3
Actually, the plug gap will be .025". I've seen these low end units with substandard ignition armatures not have the power to fire a .030" gap.
