2000 Yard machine sleve above pulley
hienzs's Avatar
05-18-07, 06:22 AM   #1
Hi and thanks for reading.
I have recently change my drive belt in my 2000 yard machine model 13an690g352 serial# 1d120b70100. when i lowered the front pulley it came of and the metal sleve above the pulley fell of with out me being able to see which way it went on. The sleve has a fat end and a skinny end. The outer diameter is thicker on one end. I can not find a manual that has an illustration so i was hoping some here might now the right way it goes on.
Thanks
Azis's Avatar
05-18-07, 07:30 AM   #2
Azis
Here is a url to the MTD archive and the manuals they have on file for your mower. http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=0&model_num=13an690g352&serial_num=1d120b70100
I can't think of anything special, it should just be a spacer. If it is not keyed and will go on either way, it may not matter. You might be able to look for wear marks that match up.
puey61's Avatar
NY
05-18-07, 10:06 AM   #3
Flange end (larger diameter) up towards engine!
