B & S problem
Old 05-19-07, 11:12 AM
Question B & S problem
I have a 12 hp b&s, mod 283707 that loses power and dies when it is hot and under load. Any ideas ?
Old 05-19-07, 11:29 AM
puey61's Avatar
Fuel cap that is no longer vented (clogged/plugged); Ignition coil failing under heat stress; Intake valve issue or exhaust or intake valve seat issue; Engine overheating due to the cooling fins being plugged up with grass/mouse nest debris. Just a few of the more common issues you may find. Good luck and keep us posted.
Old 05-21-07, 07:51 AM
Question B&S problem
Thanks for the subbestions. My parts list doesn't contain an ignition coil. What else would it be called?
Old 05-21-07, 07:52 AM
Thanks for the suggestions. My parts list doesn't contain an ignition coil. What else would it be called?
Old 05-21-07, 08:38 PM
cheese's Avatar
An armature/magneto.
