Ariens Front Tine Rotary Tiller-Belt problems
Old 05-23-07, 07:13 AM
Just started up tiller only to experience the belt coming off the pulleys, and was wondering how the belt should go on. Perhaps the tension on the belt is too loose and was wondering how this can be done. Please note the crank pulley is on the top with two larger pulleys on the bottom and in between this configuration about 3 inches from the crank pulley is another pully whick is a free floating pulley and dead center down from the crank pully.
Any more info required please advise and any help will be appreciated.
waynf
Old 05-23-07, 06:14 PM
puey61's Avatar
Need the chassis model and serial numbers and, while you're at it, post back with the make and ID numbers of the engine as well.
Trackbacks are On
Pingbacks are On
Refbacks are On
