Problem Stihl Trimmer
Old 05-23-07, 02:17 PM
C
string trimmer starts fine and easily runs like it's supposed to for about 5 ish minutes then dies abruptly and won't start until a bit cooler. only bought in 2 yrs ago, used very little,,,sadly. No exhaust blockage, right fuel mix, gap on plug is correct but the plug was a reddish color not clear on what that means. please help. thank you in advance
Old 05-23-07, 02:51 PM
repair_guy's Avatar
New Member
Try losening the fuel cap.If the trimmer runs, then the fuel cap air-vent is clogged.If engine stops again check for spark B 4 engine cools again.(the coil might be going bad)
Old 05-23-07, 05:21 PM
C
reply
we'll give that a try and let you know
Old 05-23-07, 05:54 PM
puey61's Avatar
On most Stihl's, the cap is not vented but the fuel tank itself is. There should be a fuel line inserted into the tank and will have a breather valve outside the tank attached to this fuel line. There is no decent way to check its function well so I recommend simply replacing it. I'm in agreement that it is most likely the tank not breathing.
Old 05-24-07, 12:40 AM
cheese's Avatar
Received 55 Votes on 50 Posts
I'd check for spark when it dies to verify if you're losing spark or not. I've run into bad coils on stihls once in a while. On the FS line of trimmers, their coils are made in Mexico, or in Germany. If I recall, the ones made in Germany are the ones that seem to go out prematurely. (that's not the way I would have predicted it).
Old 06-03-07, 01:43 PM
C
sorry aboout the delay in responding,,,,,
well I don't get alot of time to work on the da*n! thing but I did take the carb. off and spray "Gunk" carb cleaner through every orifice I could find. Reassembled everything (w/o any extra pieces left over) started it right up and ran like it ought to, then of course died shortly after. that wasn't it. So i left it for a couple days as I work odd hours with split days off. came back and most of the fuel had pushed itself out of the tank. Is this a sign of a non breathing cap??? and would that be the reason for not running after a bit? UUGGGHHHHH! I am not convinced that there is no spark when it dies as it will start in only a few minutes of cooling, so i will save that for just before i throw it into the creek!!!!
Old 06-04-07, 11:04 PM
cheese's Avatar
Yes...a non-venting cap will cause your problem as mentioned in the previous posts. This would be the most likely cause for your problem.
I wouldn't suspect a coil unless you're losing spark. I only added that info as a supplement to the existing info from the prior posts.
