1998 toro recycler running rough..
roadk's Avatar
05-23-07, 06:54 PM   #1
i have a this toro lawnmower from 1998 that seems to start fine, but it runs rough. even after it's warmed up, it continues to rev- to compare it to a car, it's as if you have the car idling, and you tap on the gas every 3 seconds.
never stops this 'revving'.
i put a new plug and a new filter on it this season.
any ideas? i can only assume that it's a carb problem...
thanks for any help you guys can offer
-thomas
cheese's Avatar
GA
05-24-07, 12:15 AM   #2
Yes, it's a carb problem. It needs cleaning.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
roadk's Avatar
05-24-07, 05:25 AM   #3
does the carb need to be removed to clean?
i'm wondering if this carb can be cleaned while still on the mower?
is as simple as purchasing something like gum-out or do i need to disassemble and basically rebuild it?
again, thank you for the reply and and help you can offer.
--thomas
cheese's Avatar
GA
05-24-07, 07:00 AM   #4
You might be able to remove the carb bowl and clean it out and clean out the holes in the bolt that holds it on and solve the problem. I don't know what engine you have.
God bless!
