engine governor gear
sawbones's Avatar
05-28-07, 03:20 PM   #1
Engine:B&S 26HP OHV
Model:44677
Type: 0244 E-1
I have replaced the governor gear, and now I'm ready to reinstall the gear cover. My question--the wings on the governor gear should they be closed or open when I put the gear case back on. (2) How do I go about resetting the governor control arm, so that I don't get an out of control rpm when I restart the engine.
Thank all for any advise
repair_guy's Avatar
New Member
AL
05-28-07, 03:34 PM   #2
Since your going to reset the governor arm anyway it really doesn't make a differance.Just make sure that the nipple that throws the counterweights out to the governor is behind the gov.lever.
Then to adjust losen the small nut on the gov.arm then holding the throttle on the carb. to idle, turn the gov.shaft CCW till it stops.Holding both still tighten the nut.
sawbones's Avatar
05-29-07, 05:13 AM   #3
repair guy
What exactly do you mean by making sure the govern arm is behind the nipple?
repair_guy's Avatar
New Member
AL
05-29-07, 04:33 PM   #4
Sorry about the delay in getting back with you.Internet explorer was out around here today,just noticed that I could get online.
I mean if you've already taken the gov.shaft a lose from the gov.rod,make sure the "flap" on the gov.shaft isn't laying on top of the gov.and is right in front of the nipple that controls the counterweights.
If your engine is a ver shaft anyway, A B&Smodel # has 6 #'s.Or a letter & 5 #'s
sawbones's Avatar
05-29-07, 08:06 PM   #5
Repair Guy
Thank you for your response, that is what I thought you were talking about, just wanted to make sure.
