Murray garden tractor
oxygenman's Avatar
06-02-07, 12:20 PM   #1
I have a murray garden tractor, 42" cut 16hp. The engine will turn over but there is no spark to the plugs. I have changed the seat switch, clutch switch, ignition switch, IPO switch and the fuse under the seat, but there is still no spark to the plugs. Does anyone have any idea what is wrong with it. Thanks
msidan's Avatar
NY
06-02-07, 06:05 PM   #2
Did you check the ignition coil? Remove the blower shroud, unhook the kill circuit from the coil (thus eliminating any safety switches) and then check for spark. Be advised you will not be able to turn the engine off with the key switch with the kill circuit unplugged. If still no spark, replace the coil.
oxygenman's Avatar
06-02-07, 07:04 PM   #3
No spark on Murray lawnmower
Thanks for the information. I will check it out and get back with you. Thanks again.
