HOW to tune rpm's by ear?
Lawn Toad's Avatar
06-04-07, 08:39 PM   #1
I have a Cub2180 with vanguard 18hp. and a Cub2185 with kohler 18 hp, the kohler sounds good! (My question is can I tune the one tractor rpm's to the other?) when i ran the vanguard wide open ,then I started the kohler engine about 3/4 throttle, is when they became in tune with one another.IT sounds like the vanguard is not up to pare at 3600 rpm with no load, I don't have rpm-tack .Can I do this!?
cheese's Avatar
GA
06-04-07, 10:40 PM   #2
No. You pretty much can't tune rpm by ear. You might get pretty close if you're a mechanic who has worked with small engines for years and years. Otherwise, and even then, you'll need a tach to check rpm. They're cheap. You're comparing one brand engine to another. The sounds are not the same.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
