2hp b&s backfire
Old 06-09-07, 08:16 PM
2hp b&s backfire
Hello, I have a 2 hp b&s that starts easy and idles nice but when i throttle it up it losses power and starts to pop at random through the exaust and carb.
any help would be greatly apriciated.
Old 06-10-07, 10:22 AM
Post the Briggs Model No., Type and code numbers. they should be stamped on the flywheel cover so we can see what we are dealing with. Have a good one. Geo
Old 06-10-07, 12:59 PM
here are the #s
60102 0267 01 700817
Old 06-10-07, 01:21 PM
puey61's Avatar
Could be both a valve clearance issue as well as an ignition issue. The "pop" through the exhaust indicates ignition and a "pop" through the carb indicates a problem with the intake valve clearance. OR, you may have a sheared flywheel key and this alone would explain the trouble.
Old 06-11-07, 08:58 AM
I agree with puey, it sounds like a sheared flywheel key. Have a good one. Geo
