Lawnmower will start not idle
This weekend I encountered a problem with my riding lawnmower. I was cutting the grass and ran over a branch. The belt that enables the mower to go forward and reverse came off of the pulley. I put the belt back on (I have had to do that in the past). I started the engine with no problem, when I released my foot from the brake so the engine could idle, the engine immediately cut off. I tried this several times and the engine all ways cuts off. The engine will run as long as my foot is pressing the brake, the minute that I let off the brake, it cuts off. Any ideas as to why this is happening and what I can do to fix it.
The lawnmower is a weedeater and the engine is a Tecumseh OVH13.0. I believe the serial number is WTPXS.3582AA
Thanks
Thanks
Received 2 Upvotes
The "WTP**" number is not the serial number, it is only a statement of government emissions compliance. It would be helpful if we had the ID numbers of both the chassis and engine but it appears you have a problem with the seat switch. If the switch is only a two terminal device then simply unplug it to determine if this is the trouble. If it is a four terminal switch, then post back with the ID numbers and we'll continue.
