craftsman 17hp tractor not cutting right
Old 06-15-07, 03:57 AM
B
Hi
I have a craftsman 17hp tractor, in the last few weeks when I cut the grass the mower deck has been scalping the grass it does this quite often. I have the blade up on a high setting and it still does it, it seem even though the blade is set to cut high it cuts the grass short . The mowing deck seems to be very bouncy.
I will be buying the mower deck wheels to see if this helps. It is a 3 years old tractor.
Thanks in advance for your help.
Old 06-15-07, 08:26 PM
cheese's Avatar
Received 23 Votes on 20 Posts
Sounds a lot like you have a bent blade.
Old 06-20-07, 03:23 AM
B
Sorry for not replying sooner but thanks for your help I was going to buy a new blade because the current blade looks shot. I'll try this first and see if it works.
Thanks
Paddy
Old 06-20-07, 07:16 AM
thiggy's Avatar
Do you have the pressure in your tires on the specs shown in your owners' manual? Is the cutting deck level as measured on a paved surface? Check you manual for proper adjustment of deck level.
