(ride on mower problem) mechanic can't fix.
Old 06-17-07, 06:35 AM
Unhappy (ride on mower problem) mechanic can't fix.
My X-mark ride-on mower runs fine until I engage the mower function. Then, the faster I accelerate, the slower it mows. Then, all of a sudden, something will "catch" and the mower works fine for a few minutes, then it goes back to very slow. Higher grass makes it worse. I have observed than when this "slow down" occurs the engine sort of putt-putts, and there is a smell of gas. If I don't back off on the accelerator, the machine quits. My mechanic is stumped. Any ideas?
Old 06-17-07, 11:43 AM
30yearTech's Avatar
Twin cylinder engine??
Sounds like you have a twin cylinder engine with a faulty ignition module on one of the cylinders. Loosing spark on one cylinder will cause a loss of power as well as the odor of unburned fuel.
Old 06-17-07, 05:06 PM
puey61's Avatar
Tell us, specifically, what make engine you have and crankshaft configuration and number of cylinders and post back, also, with any and all ID numbers from the engine.
Old 06-18-07, 06:41 AM
info on mower
It is a Kawasaki 23.0.
There are two "things" on the back side with the letters "OHV" and one spark plug (I think)
I could not find an ID# on the engine, but did find the following...
eXmark
S# ND10023
V#177183VA002
C#103 0287
Dec 13 00
does any of this help?
when the machine is running without the mower I have full power.
thanks -Jaye
Old 06-18-07, 02:48 PM
30yearTech's Avatar
The numbers you posted don't look familiar to me. A 23hp Kawasaki engine should have a model number like FH680.....
The engine numbers are found on a decal attached to the side of the crankcase of the engine. The model and serial number of the mower I believe should be on a plate riveted to the right hand side of the frame below the steering control arm.
In any case this should be a twin cylinder engine. It could be a bad spark plug that quits firing under a load, or still a bad ignition module that is not providing sufficient voltage to the plug to jump the gap under a load.
It's also possible that you may have a problem with one of the valves on one of the cylinders that is causing a problem.
I still think that what is happening is that you are loosing a cylinder when you place a load on your engine, or you may have a dead cylinder and you just don't really notice it until you put enough load on your unit.
Old 06-18-07, 02:52 PM
the_tow_guy's Avatar
Received 40 Votes on 32 Posts
Problem with the governor, perhaps?:
http://www.smallenginesuppliers.com/shop/html/governor_adjustment.html
Old 06-18-07, 06:38 PM
puey61's Avatar
Since you indicated a mechanic has been used, has he tested the ignition strength, on each cylinder, at cold engine? And at hot engine? Has he performed a leak-down test on each cylinder when cold? And when hot? If so, what are/were the results of each test and, specifically, the leak-down results at each given temperature?
