Kohler Command CH18S Smokes Periodically
Old 06-21-07, 06:18 AM
I have an 1864 Cub Cadet with an 18HP Kohler CH18S, it runs excellant except at times it will bog down and belch blue smoke out, then it will clear up and run fine again. I took the air cleaner off and it is soaked with oil from out of the breather tube. What could be the problem, it runs fine 90% of the time.
Old 06-21-07, 06:49 AM
First thing that comes to mind is to much oil in engine.
To check oil level in Kohler engines remove dip stick, clean, put dip stick back in oil tube and rest on top of oil tube, (do not screw cap down) remove dip stick and read oil level on stick.
