how to adjust valves
Old 06-21-07, 03:34 PM
Question how to adjust valves
Can someone please tell me how to adjust the valve clearance on an over head valve 14.5 hp Briggs and Stratton engine?
Thanks,
roustaboutx
Old 06-21-07, 04:26 PM
repair_guy's Avatar
New Member
your going to give us the engines model # to get the right spec.
Old 06-22-07, 04:20 AM
puey61's Avatar
Without the ID numbers but generally, you'll need a hex (allen) wrench and a 7/16" wrench. Loosen the jam nut with the box wrench and adjust the clearance with the hex wrench. The piston needs to be postioned at 1/4" past top dead center (TDC) on the power stroke to ensure that the MCR (mechanical compression release) does not affect your settings. Generally, the clearances will be .005" but we can better advise you with the specific ID numbers off the engine.
