No spark
romod's Avatar
06-30-07, 09:31 PM   #1
No spark
Today i tried to fire up my wizard walk behind and she wouldn't fire a bit.I took off the plug and tried two different plugs and seen no spark.I noticed a little bit of rust in the plug wire cap but my neighbor said it snapped in good and wouldn't be the problem.Do i need to order a new armature-magneto?My parts list also shows a terminal,ignition cable,which one should I order?
cheese's Avatar
GA
06-30-07, 09:59 PM   #2
Unplug the kill wire from the coil and check for spark. If you still have no spark, then the coil is bad.
Are you making sure the plug is touching the engine while checking for spark?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
romod's Avatar
07-03-07, 12:00 PM   #3
I assume your talking about the magneto,it has no listing for a coil in the parts list.But the last two days when i didn't need it,it fired right up like it usually does go figure!
duigoose's Avatar
FL
07-03-07, 12:08 PM   #4
I think some call them magnetos, might want to post some equipment info so folks can see what you have and look up parts if it goes that far.
I could type a bunch more but do what cheese said.
puey61's Avatar
NY
07-04-07, 04:27 AM   #5
Perhaps, then, a brake control cable on the fringe of usefulness. In other words, you may not be getting a good pull on the brake control bracket to fully disengage the brake/kill system.
