replace drive belt on yard machine
Old 07-01-07, 04:41 PM
Question replace drive belt on yard machine
I wish to replace the drive belt on my old MDI Yard machine. The forward/reverse shift lever goes through the belt. How do I get the old belt off? Does the shift lever have to be removed? How do I do that?
Old 07-01-07, 06:00 PM
repair_guy's Avatar
New Member
If you'd reply back with the model and serial numbers where we can look at it too, we'll be more able to help you.
Old 07-01-07, 06:03 PM
The yard machine model number is 13AS679G06262127 It is dark and raing now so it will be tomorrow before I can go find the serial number
Old 07-02-07, 02:07 AM
puey61's Avatar
This is a two-belt setup for the trans drive, which belt are you replacing, front or rear?
Old 07-02-07, 03:11 AM
I think the rear on is the one that is slipping, but while at it I'll replace both
Old 07-02-07, 04:05 AM
The serial number is 1F107C30088
Old 07-02-07, 05:53 AM
jeff194307's Avatar
If you remove the shift knob, the belt can be slipped over the shifter. To remove the belts, the snap ring on the middle pully is removed, then the pulley can be pulled up to allow the belts to be removed. You will need to tie the idler pulley away from the center pullleys while doing this and the two belt retainers must also be removed, If I remember right they take a 5/16 wrench.
Old 07-02-07, 07:41 AM
BFHFixit's Avatar
You can find your owners manual here http://manuals.mtdproducts.com/mtd/DocGetter?doc=770-10115.pdf
With detailed instructions and illustrations for belt replacement as well as other maint.
Old 07-02-07, 11:00 AM
belts installed. Thanks for the help
Old 07-02-07, 06:08 PM
puey61's Avatar
Gee, that was quick and painless...I think. Good job and thanks for updating us.
Trackbacks are On
Pingbacks are On
Refbacks are On
