Weed Eater WT3100 Starter Rope Help
Old 07-08-07, 10:22 AM
Question Weed Eater WT3100 Starter Rope Help
Rope broke. Unable to locate Service manual at MFG web site or on web.
Looking for instructions on safe removal of clutch which has Danger stamped on it. Clutch is held on drive shaft with a washer and nut and has a spring coiled inside it...is that where danger is?
Would appreciate info on service manual and any experience with this hardware.
Old 07-08-07, 12:32 PM
cheese's Avatar
I can't think of any "danger" areas in a weedeater engine other than the recoil spring for the pull rope. I assume that's the spot designated as dangerous.
Old 07-08-07, 04:00 PM
30yearTech's Avatar
Perhaps they are meaning that there is danger if you run the engine without the clutch drum in place. The clutch shoes will expand to a point that the spring could break and then the shoes will come flying off and could be quite dangerous if they hit anyone.
Just remove the nut, the clutch will come off as an assembly. There is not any danger in removing the clutch assembly. Just don't try to start the engine until you have it completely reassembled.
Old 07-08-07, 08:44 PM
Wink Thanks For Your Help
Took the nut off and all my problems were solved... easy access to the rope pulley and the rope pulley spring is secured linto the housing so all you have to do is lift the spindel off the post and return it the same position...life is sweet Thanks again for you input.
Fear = False evidence that appears real
