12.5 B&S Black Coil wire connection
Hondal's Avatar
07-12-07, 05:35 PM   #1
I rebuilt my B%S 12.5 Engine model 282707-0116 and I can't remember where to connect the black wire from the coil. I was able to start it and shut it off by grounding this wire but I need to hook it up properly. Can anyone give pointer where to connect this black wire with a small ring terminal at one end.
Al
CAMINO KID's Avatar
WI
07-12-07, 06:03 PM   #2
usually you connect the black wire from the coil to the connector on the throttle control plate. Most of these plates have a clip the wire goes into and some even will ground out the coil when the throttle is pulled past low idle.
tommyj3's Avatar
IN
07-12-07, 06:07 PM   #3
Look around where throttle cable hooks to engine, there will be a kill switch located in that area. Wire hooks to it. There will be a wire coming from key switch that goes to one side of kill switch.
