Carburetor Help
Old 07-12-07, 08:07 PM
Carburetor Help
Can someone please explain in detail the difference in the idle mixture screw and the idle speed screw on a small engine carb? Info is much appreciated.
Old 07-12-07, 09:12 PM
oldchevy4x4's Avatar
The idle speed screw holds the throttle plate (sometimes called the butterfly) in the venturi open a bit, to keep the engine running. The more it is turned in, the more it holds the plate open and the higher the engine will idle. The idle mixture screw changes the fuel to air ratio at lower RPMs. The farther in you turn that will cause the engine to run lean, the farther out it's turned will cause the engine to run rich.
