Gas Still in Oil
Old 07-12-07, 08:27 PM
Gas Still in Oil
If the fuel inlet needle is not the reason gas mixes with oil in a Briggs engine, are there any other possible causes?
Or is black oil mixed will a small amount of gas normal?
Old 07-12-07, 11:04 PM
cheese's Avatar
A bad float, bad carburetor, bad fuel pump if equipped. Gas in oil is not normal.
Old 07-13-07, 03:05 AM
puey61's Avatar
A bad inlet seat or highly excessive fuel pressure could also cause this.
Old 07-13-07, 05:57 AM
Curious, is this a rider?
Old 07-13-07, 10:09 AM
Nope, 6.0 OHV push mower. I just don't think the fuel inlet valve is/was the problem; the old looked fine.
Old 07-14-07, 03:03 AM
puey61's Avatar
JFS, is this the same mower you have at least three different threads going? May I suggest sticking with one thread per machine so that we can have some continuity and follow along as you progress, please. In other words, if you start a thread for a particular mower/machine reply back to that same topic if you have more/continual trouble with the same machine.
