buying new carb
Old 07-14-07, 03:11 AM
buying new carb
If I buy a brand new carb do I need to clean it or is it ready to go just mount it and fill the tank with gas. its one of those carb/tank models. $19.95
FITS MODELS 10A902-0196
USED BEFORE CODE DATE 96052000
(THIS IS A ORIGINAL EQUIPMENT CARBURETOR) mower is a 4hp 21 inch yardmachines
Old 07-14-07, 12:40 PM
oldchevy4x4's Avatar
If it's brand new it should be ready to go. You will probably need to buy a new diaphragm because I doubt the carb comes with one, and you don't want to re-use the old one.
Old 07-14-07, 05:01 PM
puey61's Avatar
The new carb will, in fact, come with a new diaphragm and gasket, just be sure to clean out the fuel tank well before you mount the new carb.
Old 07-16-07, 01:56 AM
should I replace the air filter also. its a foam one and the underside is black and greasy and dirty. could it be cleaned or is it beyond hope.maybe a bucket of bleach and laundry soap
Old 07-16-07, 02:05 AM
puey61's Avatar
The fact that the air filter is less than $4 to replace would lead me to do this rather than try to clean it. Be sure to apply an even, thorough, light coat of oil (SAE30 - same as in the engine) throughout the air filter.
Old 07-16-07, 08:52 AM
If the carb does not come with a new diaphgram kit I would suggest you replace it, Part No 495770 ($3.50) which is diaphgram and gasket or 5083 ($2.99 at Lowe's) the 5083 also includes the internal spring and screen tube. I just received 3 "new" Weedeater brand 5hp 22" mowers from Walmart they would not run, replaced the diaphgrams they ran great. They obviously were manufactured and sat in a warehouse somewhere and the diaphgrams stiffened. Have a good one. Geo
