11 hp briggs & stratton motor diagram
Old 07-15-07, 10:17 AM
i need to know were and how the wires/springs hook up from the governor [sp?] to the throttle part of the motor..
Old 07-15-07, 11:53 PM
cheese's Avatar
Assuming this is an old style 11hp vertical shaft engine (you didn't provide any model#) ...there's just one long linkage rod that runs through the middle of a long spring that goes from the governor arm to the throttle shaft on the carb. The hooked end of the linkage rod goes to the carb.
Old 07-16-07, 02:46 AM
oldchevy4x4's Avatar
It's pretty up front, as Cheese said the linkage goes to the hole on the carb that has the plastic bushing, and the spring goes into the hole above it. Here's a couple diagrams if you're not following
http://i199.photobucket.com/albums/aa40/oldchevy4x4/govnew.jpg
http://i199.photobucket.com/albums/aa40/oldchevy4x4/govold.jpg
