no oil to chain bar
Old 07-20-07, 02:27 PM
E
Cool no oil to chain bar
a McCulloch MAC 3516 35cc ser # 21-068917
no oil is going to bar and chain
cleaned all wood chips from saw by removing bar and chain
is ther a oil pump in the saw that feeds oil to bar
need help tp solve the oil problem
Old 07-21-07, 01:50 PM
CAMINO KID's Avatar
Smile oil pump
The oil pump for this saw is located on the crankshaft behind the flywheel. If you do a google search with the 11-600035-18 model number for a Mac 3615 under chainsaw part you may find a site that has a parts breakdown. try this one ( http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=b6d8e7cc-7614-4ad9-a718-bcf4a5e45345&cat=24&TF=epcFrame&assem=762&highlightNode=No&selAssem=2928&mdDescrip=11-600035-18%20MAC%203516%2006/93%20to%2005/96%20IPL%20211318 ) Have fun. Your line could be plugged or you have lost the pump or drive gear.
Old 09-21-07, 12:34 PM
R
I cant find the web site,says my session expired
Originally Posted by CAMINO KID
The oil pump for this saw is located on the crankshaft behind the flywheel. If you do a google search with the 11-600035-18 model number for a Mac 3615 under chainsaw part you may find a site that has a parts breakdown. try this one ( http://wssemw.arinet.com/scripts/Emp...20IPL%20211318 ) Have fun. Your line could be plugged or you have lost the pump or drive gear.
I am having the exact same problem,the saw is awesome around the house and have tried cleaning and blowing the line out,so far NO luck! It runs great and hate throwing it away jus for that. If I can see a diagram I can probably fix it.
Last edited by rron1229; 09-21-07 at 12:37 PM. Reason: Was not satisfied with question
