CO
07-23-07, 05:30 AM
Craftsman 6.5 EagerOne Mower won't start
Kicks back very hard, suspect timing but checked the flywheel and the shear pin does not appear to be broken. This was given to me with the statement that it just quit on him and he bought a new one. I think something else happened but don't know what.
Roy
Roy
MA
07-23-07, 07:33 PM
Roy, did you remove the starter cup to inspect flywheel key? I would pull flywheel to be sure.
Check the blade and adapter. Problems here could also cause kick back. Pull off adapter to be sure key inside did not shear and look at the 2 knobs on the adapter to be sure one or both did not shear/partially shear. Lastly be sure blade is tightened securely when re-installed.
GA
NY
07-27-07, 03:05 AM
Or, using a second person to assist, have one person lift up on the flywheel with hands under the flywheel and the second person whack the crankshaft with a dead blow hammer. Be sure to protect the crank threads by threading on the nut so that it is flush with the end of the threads.
MA
07-30-07, 08:18 AM
The "pins" on the blade adapter rarely "wear". Most likely they are half sheared. This along with the flywheel key being sheared tell us he hit something very hard. As Puey mentioned, check the crankshaft to be sure it is not bent. You can do it by taking measurements, I usually start with pulling spark plug, and tieing the shut off bar to the handle disengaging the flywheel brake. This will allow you to spin the blade freely. You can usually see pretty quickly if the shaft is bent.
