Ride -on mower won't start
Old 07-28-07, 09:39 AM
My Murrey Select ride-on mower will not start. I have changed the spark plug and fuel is getting thru. checked the switches under the seat and on the reverse lever. Doesn't seem to be a spark. Any ideas please would be greatly appreciated.
Old 07-28-07, 05:51 PM
msidan's Avatar
Does the starter engage? Unhook the kill wire from the coil and again check for spark. Let us know your results.
Old 07-28-07, 05:56 PM
puey61's Avatar
Do you get any noise when you turn the ignition key to the start position? I'm unclear if you have a "spins, no start" issue or a "no spin" issue. Any time you need help from us, or any other topic for that matter, you need to provide us with the ID numbers of that which you need help with. This helps us help you. Furthermore, on the majority of lawn mowers with only a few exceptions, the tractor manufacturer and the engine manufacturer will be two different companies and there will, therefore, be two seperate ID numbers we'll be concerned with...chassis ID and engine ID. Each will be found somewhere on their respective areas.
Old 07-29-07, 08:56 AM
Unhappy
It's a Briggs and Stratton engine in a Murray Select ride-on mower purchased from Home Depot. Yes the engine turns over on the key but will not fire. I have now flattened the battery!!!!
Old 07-29-07, 02:33 PM
msidan's Avatar
Sorry, we need more info than that. There are many different tractors that say "murray select" and have a Briggs engine. Engine and chassis numbers please so we can see exactly what you have.
Old 07-29-07, 02:39 PM
msidan's Avatar
Also, did you do what I asked you to with the kill wire?
