Choke Problem
Old 07-29-07, 03:43 PM
Choke Problem
I have a 2001 Sear 32cc Timmer. The timmer start up without little or no problem. But once I've started the timmer and move the choke to the OFF position, the trimmer stalls. I've also fell that I'm losing power do to it. Any help would be great. Thanks
Old 07-29-07, 06:12 PM
duigoose's Avatar
My first guess would be to check the spark arrestor in the muffler but like I said that is a guess.
Old 07-30-07, 07:56 AM
msidan's Avatar
Sounds like the carb should be cleaned also. I wouldn't put a lot of money into this machine, though.
Old 07-30-07, 11:35 AM
repair_guy's Avatar
New Member
Muffler clogged up
Yeah....sounds to me too that the spark arrestor does need cleaning,like duigoose said.Or maybe the exhoust ports themselfs (the three holes in the cylinder behind the muffler).Your carbuator may need adjusting,if even that,but I don't think that a carb. cleaning will cure the problem.
Old 07-31-07, 03:39 AM
puey61's Avatar
Running on choke indicates a carburetor in need of adjusting, minimally, or a reconditioning with a rebuild kit. Power loss usually indicates a plugged exhaust system.
Old 07-31-07, 12:12 PM
These suggestions are great. I'm going to try them in the next couple of days. I'll post back when when I've finnished. Thank you all for your assisance.
