international harvester brush hog
bought one for the golf course i work at and i think it needs a output seal for the gear box, its a 72" 3 point connection with two blades, everything else on it is rusted so no ser.# or mod.# dont even know what year it is
any help would be great
chris
chris
IH rotary cutter
You can probably get parts for the cutter at your nearest CaseIH dealer. The cutter was produced in Memphis, TN plant in the 70's. I am not totally sure but I think the model # is 510. There were no serial number plates on these cutters.
Hope this helps.
Hope this helps.
IH Rotary Cutter
Here is a little more help. Go to this location: https://webparts.pvassociates.net/cnh/main.php
Type in 510. A group of model 510's will appear. Choose the 510 rotary. You will find a complete parts listing for the cutter you have.
Have a great day.
Have a great day.
IH Rotary Cutter
After reviewing the parts listing, I believe you must have a 310 or 410 instead of the 510 cutter. The parts listings for these are found at the same location. https://webparts.pvassociates.net/cnh/main.php.
Have a great day.
Have a great day.
