Took off TORO Deck and now does not Turn -extra spring
brianbo's Avatar
MA
08-05-07, 04:07 PM   #1
Hi,
Took off my Deck on my TORO riding mower (212-502 I think) to have it welded and now the deck does not Turn after I put it toether.
I have a leftover spring that attaches somewhere. Does it go to Idler pulley as I saw was some posts but I thought the spring came from the back near the spindles.
Alos, the manual said the front trunnion closest to the front pulley under the engine should be 1 inch from a bracket attached to the rider frame. This trunnion slides through a piece when it goes through the bracket and a cotter pin holds it in place. When I put the cotter pin in, the trunnion just slides back and forth this piece and there is no tension. Is that what the spring is for?
Thanks for any hekl- I looked at it for a couple of hours today and had to leave it.
cheese's Avatar
GA
08-05-07, 09:15 PM   #2
I don't have any Toro literature, or much experience with them to know off the top of my head where the springs go on any given Toro. If the PTO clutch is electric, then I would say the tensioner pulley must have a spring attatched to keep the belt tight. If not electric, then the spring probably goes between the moving end of linkage for the clutch, and the arm that the tensioner pulley is attatched to.
Maybe you can find a diagram here: http://www.partstree.com/parts/?lc=toro_consumer&mh=8
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
