Keeping Briggs & Straton Lawnmower engine running
Old 08-08-07, 11:18 AM
R
My tw0 year old lawnmower engine starts fine buts looses power then quits.
After a time will start again, but the time of running seemed to be less and less.
Appears that it has a gas problem and I am not a handy man,with small engines. wish I were thanks Jack
Old 08-08-07, 11:33 AM
duigoose's Avatar
Post some model numbers from your engine and folks will be glad to help. Let us know if you need help finding them. So far my novice self is guessing fuel problem too.
Old 08-14-07, 03:01 AM
puey61's Avatar
What's the status of your trouble and diagnosis, Rosegrower? If still unresolved, as Goose indicated, post back with specifics. Walk-behind mower? Riding mower? Post back with ID numbers off the chassis as well as brand and ID numbers of the engine?
Old 08-18-07, 10:28 AM
K
I hope I can tack on to this thread.
I have the same issue. I have a craftsman 6.5hp mower. (model 917.388510) If I prime the mower, it will start. however it will die once that primed fuel is gone. If I start it and then continue to press the prime button it will continue to run.
I have change the oil, gas, spark plug, air filter, and the blade (I know it's not this, just wanted to add) and no difference.
I then took off the air filter and the gas line. I sprayed brake cleaner around the engine and in the carburetor. I then replaced the gas line because the old one was dry rotted. I checked the nozzles in the gas tank and the engine and both were clean.
I've had the mower for about 4 years and have completely neglected it until today. :-(
It worked fine the last time I used it, the only thing I did before I tried to run it was add gas.
Old 08-18-07, 01:03 PM
repair_guy's Avatar
New Member
Rosegrower,Sounds to me thet you might have a fuel venting problem.Ether the vent in the cap is cloged or there is something inside the tank floating down and covering the outlet hole.
Old 08-18-07, 01:16 PM
G
Received 5 Votes on 5 Posts
krstofer
start yourself a new post so it isn't so confusing, I don't think you have the same problem and things get real messy and confusing when we are trying to solve 2 different issues at the same time. Have a good one. Geo
Old 08-18-07, 08:17 PM
cheese's Avatar
Received 30 Votes on 25 Posts
I think you need to clean the carburetor krystofer.
