Trimmer: Idle to full speed bog and stall
Old 08-08-07, 11:18 AM
Z
Well, I must be getting out of the wrong side of bed these days! What worked great last week doesn't work right today. More specifically, my John Deere C1200 trimmer suddenly doesn't want to run at any rpm above idle and the idle isn't so smooth anymore either. Give it a little gas and it just lays down and dies.
What I've done/looked at:
Got spark
Clean fuel
Removed carb/needle and clean out passages with carb clearner and compressed air
Fiddled with both the low and high speed adjustments
Result:
I can proudly say that it doesn't run a damn bit better.
Any suggestions will be humbly accepted.
thanks,
barry
Old 08-08-07, 11:29 AM
duigoose's Avatar
check your muffler and/or exhaust port for excessive carbon buildup. look real close at the spark arrestor screen in the muffler. I'm not familiar with your trimmer so I'm just guessing this is a 2-cycle
Old 08-08-07, 06:02 PM
30yearTech's Avatar
Also you might want to look for a possible source of an air leak. Look for a loose carburetor and or insulator. Check the cylinder and crankcase cover on top make sure they are good and tight. Check your fuel line and make sure it does not have any pin holes in it. Last but not least, check the fuel pickup filter.
If all of the above check out then the other possibility is a problem with your carburetor.
Old 08-08-07, 07:58 PM
H
I can agree here. I have seen 2 John Deere weedeaters do the same exact thing. New muffler pretty much set them good to go (don't know if screen is in there too though). All in all, much better performance. Not brand-spanking new, but much, much better.
Old 08-08-07, 09:27 PM
I agree with the carbon build up in the muffler but also check that intake air filter and make sure it's clean too.
Old 08-09-07, 08:16 AM
Z
Trimmer: Idle to Speed bog and stall
Thanks to All for the good suggestion on the bogging problem.
I'll check for carbon in the exhaust port and muffler screen if equipped. I'll also double check the fuel lines too.
I'll let you guys know what I find this weekend for the curious among you.
many thanks for the help,
barry
Old 08-10-07, 09:34 AM
Z
Right on target!!
Thanks Guys you were dead-on with the plugged exhaust. The spark arrestor screen was 98% plugged!! I'm surprised it ran as well as it did during the last couple of weeks before cleaning it.
It starts great and really runs well.
I do appreciate all the input.
thanks again,
barry
Old 08-10-07, 04:41 PM
cheese's Avatar
Received 32 Votes on 27 Posts
zoomzoom, glad to hear you got it fixed. Great bunch of folks here, huh?
