Echo blower, no spark
birch's Avatar
NY
08-12-07, 09:51 AM   #1
Hey, i recently bought an echo 620 blower and it ran great--started on 1st pull. But the last time i went to use it, it wouldnt start and made no attept to start. I changed plug and gas--no start. I decided to hold the spark line while pulling starter to test tfor spark. Unfortunately, i didnt get the shock i was looking for. Any ideas on what could have caused the spark failure or how to go about fixing it?
Thanks
birch
I bought it used, so no warranty
30yearTech's Avatar
TX
08-12-07, 10:06 AM   #2
Disconnect the kill switch lead wire and retest for spark. If still no spark then the ignition module will probably need to be replaced.
The ignition modules on Echo products have a lifetime warranty for the part only. So even if the warranty is expired on the blower, a dealer should replace the module for the cost of the labor only.
msidan's Avatar
NY
08-12-07, 11:57 AM   #3
Thats some way to check for spark! All you have to do is hold the sparkplug to a metal part of the engine and pull the starter, but hey, whatever works for you...
geogrubb's Avatar
MO
08-12-07, 01:04 PM   #4
It works best if you're bare foot and standing in a puddle of water,lol. Have a good one. Geo
BFHFixit's Avatar
KS
08-12-07, 04:50 PM   #5
Its a way of testing that sometimes is the only option. Rewind removed and or no electric start, grab the lead and ground your hand to the block and spin the flywheel by hand, not much of a twinge but nuff to tell.
geogrubb's Avatar
MO
08-12-07, 07:20 PM   #6
BFH, I agree and sometimes even when all the resourses are available you just can't see the spark arc when holding the plug to the block, especially when you are doing it all by yourself. However you can feel the tingle and in some cases a big tingle. Have a good one. Geo
puey61's Avatar
NY
08-13-07, 03:29 AM   #7
The wire that 30-year mentioned to disconnect must be disconnected at the ignition coil for the test to be absolute. If you disconnect it at the kill switch then you are not eliminating the wire, itself, as a potential problem.
