push mowers hard to crank
Old 08-15-07, 11:33 AM
I have two push mowers, both are hard to crank and get started. The only way that I can get them to start is spray starting fluid into the carburetors. When I do that, they will start and run just fine. One has a Briggs and Stratton engine and the other has a Techumsa. Thanks in advance for any help or tips on fixing this problem.
Old 08-15-07, 02:17 PM
CAMINO KID's Avatar
How are the primers on both of these units. It sounds like the primers are not putting enough fuel into the system. Look for holes or torn edges. Depending on the engine models (which you do not give) there are other spots to look at.
Old 08-16-07, 06:31 PM
puey61's Avatar
Sound like you will need to service the carburetor on each one. The fact that you spray starting fluid into the carb throat and it still will not stay running indicates a fuel restriction in the carb or a lack of necessary vacuum and compression in the combustion chamber. But, I'd say it is a carb issue though.
