Poulan Chainsaw slows under load
jpokalsky's Avatar
08-22-07, 07:15 AM   #1
My 16" Poulan slows considerabily when I lay it on a branch. I've cleaned the bar, new chain and sparkplug, cleaned the air filter. Some improvement ,and it runs like it's old self before trying to cut, but I can't use it to cut as the chain slows down too much. Any suggestions.? I'm capable of taking it apart to work on it.
30yearTech's Avatar
TX
08-22-07, 08:24 AM   #2
Possible carburetor adjustment, sounds like it might be a little lean on the high speed circuit. Try opening the high speed adjustment screw on your carburetor 1/8 to 1/4 turn out (ccw) and see if that helps any.
You also may want to check the fuel filter in the fuel tank, it may need to be replaced.
jpokalsky's Avatar
08-22-07, 12:57 PM   #3
Thanks
I'll give it a shot.
Joe
puey61's Avatar
NY
08-23-07, 04:04 AM   #4
If the engine is not falling on its face and the chain is simply bogging out then perhaps you have a clutch that is slipping by way of a weak spring or worn clutch shoes or a worn bearing.
oldchevy4x4's Avatar
TN
08-23-07, 12:35 PM   #5
Maybe the bar need to be dressed? With the chain off run your fingers from the center of the bar, down off the bottom edge and up off the top edge. You should not feel a lip at the edge at all. If it gets too bad, that lip will end up as wide as the chain and it won't cut worth anything.
HotxxxxxxxOKC's Avatar
OK
08-23-07, 06:08 PM   #6
How many hours are on this machine? I believe typical Poulans, except brand new Cali spec saws have only like a 15 hr life span before rebuild....I could be wrong.
jpokalsky's Avatar
08-25-07, 05:10 AM   #7
Thanks Guys, one more thing
It's got a least 15 hours on it. Given the replies I'm thinking its a clutch problem and posssibly more as I worked the saw pretty hard. What's in a rebuild? Carb, Clutch and Bar? I hope you get back to me as I want to order the parts ASAP. Depiste the bad press on Poulans this has been a good littls saw for me and I want to keep it despite expecting my new Husqvarna 460 20 to arrive soon.
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
08-26-07, 10:21 AM   #8
Excessive Carbon
Hello: jpokalsky
Possible the muffler and/or spark arrester (or both) are restricted with excessive carbon. A restricted exhaust system will or can display the symptoms you describe. Loss of power under a load.
Before attempt any other repairs and or carb etc. adjustments, I suggest checking the entire exhaust system. Any of the already suggested possibilities may still exist. Restricted exhaust is just one more potential cause.
Regards & Good Luck. Sharp Advice.
20+ Year Vocational Small Engine Tech. Web Site Host, Forums Monitor and Multiple Topics Moderator.
