flooded/leaking carburator
vernon1959's Avatar
CT
08-22-07, 03:22 PM   #1
my aries snowblower (2 stage) leaks from the carburator, i had this rebuilt last winter. when i called and spoke to them about it this week they stated that the warrenty for work was only good for 30 days.
it leaks and is filling up the head. i am not very machanically inclined and any help in resolving this issue would be greatly appreciated.
thanks in advance for any help!
geogrubb's Avatar
MO
08-22-07, 07:45 PM   #2
We really need the Model, Type, et. from the engine to be of any real help. It sounds like the gas tank is above the carb and you have a bowl type carb which would indicate you left untreated fuel in the engine which has evaporated and turned to varnish and the float is stuck open, which would inficate the need to soak the carb in a bath type cleaner to desolve the varnish. However this is just a guess at this point without knowing what type of engine you have. Have a good one. Geo
vernon1959's Avatar
CT
08-23-07, 02:59 AM   #3
leaking carb
Thanks for the info, I'll get the required information
Posted By: geogrubb We really need the Model, Type, et. from the engine to be of any real help. It sounds like the gas tank is above the carb and you have a bowl type carb which would indicate you left untreated fuel in the engine which has evaporated and turned to varnish and the float is stuck open, which would inficate the need to soak the carb in a bath type cleaner to desolve the varnish. However this is just a guess at this point without knowing what type of engine you have. Have a good one. Geo
puey61's Avatar
NY
08-23-07, 03:44 AM   #4
Being an Ariens two-stage thrower this will be a four-stroke Tecumseh engine with a gravity fed carb. Geo is most likely right that you will need to soak and recondition the carburetor and this is quite common with todays gasolines. If you do not take the proper steps to prevent varnish accumulation during storage periods, particularly with summer-stored equipment, then you will have this trouble yearly.
