riding mower stalls
riding mower stalls
My riding mower stalls when I engauge the blades. Any sugestions? thank you. Bopesh
Are you saying stalls like you turned the key off? Does it run fine until you engage the blades? Right now my guess would be something with a safety switch but that is just a guess. What type mower is this and can you provide some numbers, model, etc.....
That's pretty vague, can you give us more info? What kind of mower? Electric PTO, or manual PTO? Does it have a reverse operator safety switch? Your mower make and model will help us get a little more of an idea of what is wrong, rather than trying to guess.
riding mower stalls
Sorry, I should have given you more info. The mower is electric start.
Craftman Model 502 254131 Serial Number 113706110
It is a 30 in cut, 8 HP, 5 speed mower
It stalls when I engauge the Blade.
Thanks, Bopesh
Thanks, Bopesh
Thanks!
Ok, I looked up your mower electrical and it doesn't have a reverse mowing switch, so I'll go with Puey61 and say you have a bad seat switch, or bad connection at that switch.
This is assuming the engine just dies like it was switched off. If it dies a more slow death, as if it were struggling to keep running, then I'd suggest you have a problem with the PTO (siezed bearings in the mandrel, or jammed blade, etc...).
