fuel line question
Old 08-30-07, 10:59 AM
fuel line question
whats the standard size fuel line. I mean like is it 1/4 3/16" 5/16
i need a new one for a lawnboy commercial lawnmower 2 cycle engine. don't have the model number at this time. heres a pic of the mower. the old one is ripped off at the tank and won't reach so it can't be repaired.
http://img265.imageshack.us/img265/8072/dsc02107gj8.jpg
http://img127.imageshack.us/img127/5067/dsc02106ai7.jpg
Old 08-30-07, 12:21 PM
repair_guy's Avatar
New Member
The standerd 1/4 ID X 7/16 OD black line, like goes on B&S or Tecumseh will fit or if there is any of the old fuel line left at all you can measure how much you need and take it to your local small engine shop and they can match it for you.
Old 08-30-07, 01:25 PM
so a role of 1/4'' clear fuel line would work.
Old 08-30-07, 05:19 PM
puey61's Avatar
I'm not familiar with this model but it should be 1/4" (ID) but i've seen some Lawn-Boys with 3/16". Based on the fact that it is a "commercial" mower, I'd go with the 1/4". Yes, clear line will work but braided is better. I like Tecumseh's fuel line.
Old 08-30-07, 05:28 PM
30yearTech's Avatar
With a hose clamp that you can tighten down you could probably get away with 1/4" id fuel hose on a Lawnboy, but 3/16" ID line is what you should really be using on a Lawnboy mower.
Old 08-30-07, 06:02 PM
Ok not sure if it helps but heres the model number 8481AE SERIAL F195BO147
yes it is a commercial lawnmower made for commercial use based on the fact that its a 1 gallon gas tank electric start only grease fittings for a grease gun also it has a 20 inch aluminum deck
Old 08-30-07, 06:54 PM
OK the I.D size is half of 1/4 so what size would that be
Old 08-30-07, 07:05 PM
cheese's Avatar
Half of 1/4 is 1/8. That's not the size of the fuel line on your mower.
Old 08-30-07, 07:10 PM
thats what size the inside hole is
Old 08-30-07, 07:17 PM
It uses 1/4 in black rubber fuel line like the B&S and Tec's. I think that is a commercial grade mower but not a true commercial mower or it would have an orange tank and red wheels and have a bush guard in front of the engine. Have a good one. Geo
Old 08-30-07, 07:18 PM
cheese's Avatar
The inside hole of your fuel line? That's tiny...more like weedeater fuel line. I don't think I've ever seen 1/8 fuel line on a lawnmower.
Old 08-30-07, 08:22 PM
Sounds like you might be referring to the primer hose?
Old 08-30-07, 08:33 PM
no this line goes from the tank to the carb and is broken off. the outside is about the same if not slightly smaller then a standard fuel line
Old 08-31-07, 02:01 AM
puey61's Avatar
I'd recommend going to your local shop and purchasing short pieces of 1/8", 3/16" and 1/4" fuel lines and see what fits up.
Old 08-31-07, 07:38 AM
30yearTech's Avatar
I checked my gateway cd and it lists 3/16 ID fuel line for this model as well as most all others that I glanced at while I had it out and was checking too see if I could find any models that listed 1/4" line. I am sure you could use 1/4" line as long as you use a screw type hose clamp that will hold the fuel line tight.
Old 08-31-07, 03:35 PM
maby someone put a differnt fuel line on here then as 1/8th is what the hole size is. Want me to post picks. the old line is still on the mower but is broken off at the tank and it won't reach to repair
Old 08-31-07, 04:32 PM
ok removed the old fueline. the opening is 1/8 the outside around 1/4 as the walls are 1/8 thick. but the carb and fuel tank nozzles are 1/4 big so I need a 1/4 OD fuel line correct.
Old 08-31-07, 05:09 PM
30yearTech's Avatar
The fuel line should be slightly smaller then the fuel fitting to assure a snug fit that will not leak. 1/4" fuel line should work just fine, as long as it's clamped snuggly to the fitting.
Old 08-31-07, 05:23 PM
what about 5/16th that just right
Old 08-31-07, 05:52 PM
30yearTech's Avatar
Uh flirty that's larger then 1/4" by 1/16" of on inch.
1/4" would be the same as 4/16".
3/16" would be 1/16" smaller then 1/4" line.
1/8" is 1/16" smaller then 3/16" or is half as small as 1/4" line.
When we are referring to the size of the fuel line we are all talking about the inside diameter "ID" not the outside diameter "OD". The only time the outside diameter is going to be an issue is when it needs to either seal through an opening or has a limited amount of space it can fit in.
  #21
Old 08-31-07, 06:30 PM
OK i'll just get 1/4 ID fuel line can get a 25 foot roll online for around $14 with shipping so I will go that route.
  #22
Old 08-31-07, 07:00 PM
30yearTech's Avatar
If you don't need 25 feet of fuel line, you can pickup 1/4" ID fuel line at any auto parts house and just buy the length you need. You should be able to get what you need for less then $5.00
Just in case you don't really want a 25 foot roll.
  #23
Old 08-31-07, 09:52 PM
oh what part number is the air-filter cover again model 8481AE serial F195B0147
  #24
Old 09-01-07, 03:57 AM
30yearTech's Avatar
Lawnboy / Toro Part # 611377 Air Filter Cover
  #25
Old 09-01-07, 04:20 AM
ok got all the info I need thanks for the help the cover is only less then 2 dollars can't beat that
  #26
Old 09-01-07, 12:13 PM
Something about a picture being worth-----whatever, check the photo's
http://s190.photobucket.com/albums/z120/geogrubb/?action=view&current=Picture001-1.jpg
http://s190.photobucket.com/albums/z120/geogrubb/?action=view&current=Picture002-2.jpg
http://s190.photobucket.com/albums/z120/geogrubb/?action=view&current=Picture003-1.jpg
  #27
Old 09-01-07, 03:16 PM
theres nothing written on my fuel line.
  #28
Old 09-01-07, 04:16 PM
Flirty;
I/We are not concerned with what you have, we are concerned with what you need to replace the current one to solve your fuel line problem. The photos are to illustrate one option that will work. Also, if your mower is a Commercial grade it will have a plastic carb and a tapered fuel inlet so several lines will fit. It is Commercial it will have a metal carb and ridged fuel line asccess from the carb and is not so ascessable. Have a good one. Geo
  #29
Old 09-01-07, 04:38 PM
Originally Posted by geogrubb View Post
Flirty;
easy there temper temper. you posted picks so I replyed you should explane yourself better. anyway yes the carb is metal the old fuel line had a rib going across it yes its hard to access the fuel line but I got it off the carb nozzle is tapered along with the tank nozzle. no primer on this model. I will order 1/4 fuel line unless you know of a size smaller that would work as the nozzles are 1/4 big. if 1/4 line is fine then this thread is solved unless it doesn't start.
  #30
Old 09-01-07, 06:44 PM
flirty;
No temper,temper, I am just here to try to provide a solution to a problem that if taken to a service center will cost you appx $65.00 per hour after the initial diagonistic cost to $89.95 or whatever. However we can't help you if you don't help us. The pic's show your tank with fuel line attached, the fuel line size, specifications and manufacturer. Thats about as good as I can get. Have a good one. Geo
  #31
Old 09-01-07, 07:09 PM
flirty;
sorry ok anyway like said I will go with 1/4 inch fuel line as thats what everyone suggests and will get some hose clamps.
  #32
Old 09-02-07, 09:01 PM
does anyone know where I can get lawn-boy paint so I can repaint it
  #33
Old 09-03-07, 12:18 AM
repair_guy's Avatar
New Member
Lawnboy Paint
The people at your local small engine shop (who also sales/services Lown boy)
will be able to order it for you,if they don't already have some in stock.
Happy Laber Day - Drive safely
Don't eat too much.LOL
  #34
Old 09-03-07, 08:29 AM
Dupli-Color engine enamel in "Grabber Green" is almost identical to Lawnboy and is about $3.00 at Home Depot. Have a good one. Geo
  #35
Old 09-05-07, 10:08 PM
ok how much should I expect to pay for 2 feet of 1/4 ID fueline at a small engine shop whats the average. do you suggest a smaller size then 1/4 that would work. so far I poured fuel into the carb would not start poured it into the sparkplug hole would not start. tries to. plug is warm so its getting spark
  #36
Old 09-06-07, 06:39 AM
nevermind went out to the shop and got 2 feet of 1/4 fueline for just over $4 installed it and its a snug fit so will see if this gets it to start. will pick up a gallon of fuel as mower says 8 oz per gallon of gas this is a 2 cycle BTW
  #37
Old 09-06-07, 08:56 AM
Well now what. refuses to start. even with starting fluid it will not start it wants to but won't. any ideas.
  #38
Old 09-06-07, 09:36 PM
cheese's Avatar
Is it sparking?
  #39
Old 09-06-07, 10:15 PM
Is it sparking?
plug is warm to the touch so I assuming it is.
  #40
Old 09-07-07, 07:14 AM
Ok checked for spark and it does have spark. its getting fuel but it still refuses to start. it trys to but won't. sprayed starting fluid into the carb put gas in the sparkplug hole and it trys to start but just won't. compression is 55 PSI.
