06 ariens st11528 thrower
JOHNJOHN's Avatar
09-03-07, 07:01 PM   #1
Does anyone know if the tecumseh 632334a carb (adjuatable) will fit this newer engine?
If not which one will ?
flirty1's Avatar
MI
09-03-07, 07:54 PM   #2
need somemore info whats the engines make model HP is this carb new used what engine did it come off o
JOHNJOHN's Avatar
09-05-07, 06:24 PM   #3
It's a A Tecumseh 11.5 hp snowking on an Ariens Snowblower.
The carb is a new (older style) that I'm looking to order.
puey61's Avatar
NY
09-05-07, 06:32 PM   #4
On a sticker on the blower shroud just below the carburetor will be the model, specification and serial numbers of the engine. Post back with these and I can do a will-fit check for you. Initially, though, I believe that this is the same mount style carb as well as the fuel inlet position as the original except that the choke control lever will be different. But, post back with the ID numbers.
JOHNJOHN's Avatar
09-06-07, 08:20 AM   #5
Posted By: puey61 On a sticker on the blower shroud just below the carburetor will be the model, specification and serial numbers of the engine. Post back with these and I can do a will-fit check for you. Initially, though, I believe that this is the same mount style carb as well as the fuel inlet position as the original except that the choke control lever will be different. But, post back with the ID numbers.
Will do. Thanks.
