Toro Snowblower not throwing snow
Old 09-08-07, 02:36 PM
Lightbulb Toro Snowblower not throwing snow
I bought a used 2 stage Toro snowblower from a friend. I don't have a manual for it. When we had a snowfall over 6" the blower picked up the snow but the motor was not giving it enough power to throw the snow more than a foot or two. I have previously owned a snowblower like this one that would throw the snow so high the snow would fly over our full size van, and over the 4" chain link fence landing in the yard. A distance of roughly 20 feet and over 8' high. The timing or idle seem to be set too low on this new (used) one. Is there anything I can do to speed up the motor?
Old 09-08-07, 06:17 PM
It has been over 100 lately here in St Louis and your talking about blowing snow. Oh well, we need to know the model numbers etc. usually found on the engine schroud before we can start to determine what might be the problem. Have a good one. Geo
Old 09-09-07, 06:45 AM
puey61's Avatar
Do the engine running RPM's seem OK to your ear under no load situations? Do the RPM's drop off significantly when you encounter snow? I'm thinking you need to remove and service the carburetor. Post back with the chassis' ID numbers as well as the engine's ID. It is quite rare for the governor or speed control bracket to come out of adjustment or for the governor spring to weaken to the point that your experiencing.
Old 09-09-07, 09:16 AM
CAMINO KID's Avatar
Too early for snow here also. You might look at removing the carb heat stove cover and check the throttle shaft on the carb with your finger to see if it is not seized up from setting. It sounds like the engine is not responding to load and the high rpm's are not occuring. Most of these Toro 2 stage units run about 36-3800 rpm's at full throttle and throw the snow real well. If the engine is okay then check the auger belt tension with the engine off and the auger engaged. The idler on most of the 2 stage units have a small slot that can apply more tension on the belt. Good Luck
Old 11-25-07, 03:18 PM
check the shear pin(s) on the auger also
