Homelite Blower won't start
Old 09-08-07, 03:22 PM
A
Hello, used this without problems with little use and worked fine; now it won't start or even attempt to start..any suggestions? I tried cleaning out the carburator but it did not help..
Old 09-08-07, 06:11 PM
G
Received 31 Upvotes on 29 Posts
First we need Model number and any other identification you can find before we can help very much. Have a good one. Geo
Old 09-09-07, 06:46 AM
puey61's Avatar
Received 2 Upvotes on 2 Posts
Ensure you have: Spark (ignition); Compression; And, fuel delivery to the combustion chamber.
Old 09-09-07, 09:09 AM
CAMINO KID's Avatar
Another check is to see if the cylinder is tight to the crankcase. There have been a large number of these units that have come into our shop with the bolts that hold the cylinder to the crankcase either loose or broken. With this condition the fuel is not getting drawn into the unit and eventually into the combustion chamber. You may have to remove some of the engine covers to check this. Good Luck
