[email protected] 11hp Motor No Spark
Old 09-09-07, 12:52 PM
Angry [email protected] 11hp Motor No Spark
I Have A Rear Engine Riding Mower With A 11 Hp B&s Motor Model 28r707. There Is No Spark Going To The Plug. The Battery,plug,and Magneto Have Been Replaced. Also Sanded The Magnet On The Fly Wheel. Any Ideas??? Thanks
Old 09-09-07, 02:30 PM
can you post back with the riders model number and brand also. sounds like it might be a safety switch problem
Old 09-09-07, 03:43 PM
puey61's Avatar
Isolation of trouble is necessary. Begin by disconnecting the kill circuit wire from the ignition coil (Magneto) at the point that it joins the junction block at or near the speed control bracket (governor). If you have spark at the spark plug after disconnection then you will likely have a safety switch issue and the most likely culprit will be the seat switch. If you have no spark at this point then you have a faulty (bare wire) kill wire running to the coil, assuming the coil you installed is new AND good AND gapped correctly.
Old 09-11-07, 08:56 AM
Talking B&s 11 Hp Motor No Spark
THANKS FOR THE INFO.
I REPLACED THE SEAT SAFETY SWITCH AN IT FIRED RIGHT UP. I WOULD OF REPLACED EVERYTHING BUT THE SAFETY SWITCHES AGAIN THANKS!!!!!!!!!!!!!!
Old 09-11-07, 12:33 PM
puey61's Avatar
Fantastic and thanks for updating us on the status.
