8hp Briggs/7hp Briggs ignition issues
Old 09-09-07, 07:21 PM
L
my 7hp (170432) had no spark, so I replaced the coil and points set (new) from my 8hp (190432). The 7hp runs fine. I replaced the points/coil with the solid state coil #398811 in the 8hp and now it will not run. It backfires and spits sometimes and I get some fuel dripping from the bottom of the carb. I am certain the flywheel key is intact and not sheared and I tried starting with the kill wire connected and not connected, and two different spark plugs getting the same result. What could be wrong? I installed the coil as the directions stated. I can't stop scratching my head.. any thoughts?
Old 09-09-07, 07:59 PM
cheese's Avatar
Received 149 Upvotes on 136 Posts
Sounds to me like either the key (which you sated you're certain it's ok), or the carb is flooding.
Old 09-10-07, 05:22 PM
L
The 8hp ran fine before the coil swap. I'm going to pull the flywheel again and make sure the key is fine.
Old 09-10-07, 08:03 PM
L
Well, I thought a new flywheel key would last longer than it did, but in fact it was sheared off. I replaced it with another new one and it now runs again. Thanks for your reply.
Old 09-10-07, 08:44 PM
msidan's Avatar
You have to really torque the flywheel bolt on. I mean REALLY tight! Or the key will just shear again. I don't know the exact ft. lbs (65 I think?)
Old 09-11-07, 12:42 PM
puey61's Avatar
Received 2 Upvotes on 2 Posts
65 foot pounds is correct on the flywheel nut torque.
Old 09-11-07, 06:43 PM
L
Alright. I'll double check it and make sure its tight enough. How exactly are you supposed to torque that starter clutch on there and with what? I've been using a channel-lock pliers and just crankin it down.. (my engine doesnt have a nut, just a washer and recoil starter clutch hold the flywheel on)
Old 09-11-07, 07:50 PM
G
Received 31 Upvotes on 29 Posts
Can you post a picture of your setup, I have never heard of yours. Have a good one. Geo
Old 09-11-07, 10:15 PM
cheese's Avatar
Briggs gas a special tol for turning the cranking ratchet, but you can use the channel locks if you can get a good enough grip, and hold the flywheel well enough. You won't be able to get a torque reading this way, but just tighten the stew out of it...that'll be close enough.
Old 09-13-07, 07:53 PM
L
If you have Adobe Acrobat Reader, look at the illustrated parts list here: http://www.briggsandstratton.com/ipl...100/MS5850.pdf
its part #66 on page 6 of the .PDF... Most briggs engines I've ever had or worked on had this style of start mechanism.
Old 09-14-07, 09:29 AM
G
Legal v8, I see now, I was thinking vertical shaft mower with the cup and stuff. Thanks for clearing up my confusion. Have a good one. Geo
Old 09-14-07, 11:47 AM
puey61's Avatar
You can purchase a Briggs starter clutch tool, part number 19244 at any Briggs service shop for around $11 and at the same shop, if they handle Stens aftermarket parts, they have a flywheel holder for this engine, part number 750-083 for around $33.
Old 09-14-07, 12:05 PM
L
Thanks for all of your replies. I will look into those tools when I get back from my weekend camping trip. have a great weekend folks!
