Ryobi 2 Stroke Engine
Old 09-14-07, 11:46 AM
Hay guys i am having major problames with my strimmer.The first was when the magneto packed up and i replaced it but when it came to starting the machine the thing was a bugger to start.The spark is ok the plug is ok i have fresh fuel.So when i actually got the damn thing to run it would only run on Half Choke with throttle fully open.As soon as i pushed the machine into fully open Choke the machine would go Bang as in its backfiring.I said to my self that sounds like the Timing is out but its a 2 Stroke and it don't have Valves so i am a bit stuck.But in my opinion there is something wrong in the carb itself maybe the jets have gone or something i don't know.If you can share some light please do thx guys.Im not Used to fixing 2 Stroke engines thay are so more complicated than Jcb Engines and this is a fact lol
Old 09-14-07, 04:31 PM
duigoose's Avatar
I don't know what a packed up magneto is but check your spark arrestor and muffler 'cause they might be clogged.
Old 09-15-07, 05:35 AM
The magneto i mentioned is the Ignition Module that generates a current for the spark plug.I have done what you said and nothing is different.
Old 09-15-07, 10:32 PM
cheese's Avatar
Received 149 Upvotes on 136 Posts
Did you set the air-gap to specs when you replaced the coil?
