replacing pistion rings
flirty1's Avatar
MI
09-27-07, 01:16 PM   #1
whats involved in installing piston rings in a lawnboy 2 cycle F series engine. I can get the rings online for around $13 + shipping. what am I in for If I decided to do this.
puey61's Avatar
NY
09-28-07, 02:40 PM   #2
Post back with the model and serial numbers off the frame so I can have a look at what you have.
flirty1's Avatar
MI
09-28-07, 04:42 PM   #3
model 8481AE serial F195B0147
geogrubb's Avatar
MO
09-28-07, 08:32 PM   #4
It was made between 1987-89 and unless you're doing it for the fun of it, NO way. From my experience(which is nil) first separate the case,take out the crank and main bearings and seals, remove rod cap, out fall the bearings(33 not 32 OMC literature says there is 33, 17 one side 16 the other).
Have a good one. geo
puey61's Avatar
NY
09-29-07, 08:32 AM   #5
Geo is correct, this is a complete engine disassembly. And you must replace the rod bearings as they will fall apart upon disassembly. You'll also want a complete gasket and seal set.
flirty1's Avatar
MI
09-30-07, 03:46 AM   #6
Posted By: puey61 Geo is correct, this is a complete engine disassembly. And you must replace the rod bearings as they will fall apart upon disassembly. You'll also want a complete gasket and seal set.
so in other words not worth it. are all engines that hard or just this one I'll just put a new engine on it
geogrubb's Avatar
MO
09-30-07, 06:45 PM   #7
flirty, if you have a F series lawnboy engine that needs rings it has a gazillion hours on it or was truely mistreated OMC made an amazingly tough 2-cycle so if it needs rings it will need all the other innards also. Have a good one. Geo
flirty1's Avatar
MI
09-30-07, 10:02 PM   #8
Posted By: geogrubb flirty, if you have a F series lawnboy engine that needs rings it has a gazillion hours on it or was truely mistreated OMC made an amazingly tough 2-cycle so if it needs rings it will need all the other innards also. Have a good one. Geo
so is there anything else that will cause low compression 55 PSI. will have to pull the engine to remove the muffler. what HP is this engine do you know.
puey61's Avatar
NY
10-01-07, 11:36 AM   #9
My lookup doesn't indicate the horsepower but I believe that it is 4 to 5 horse. The other area of concern for such low compression is the cylinder.
