Mac chainsaw fuel line routing
Old 10-09-07, 11:49 AM
I recently came across a very lightly used McCulloch FR 2.1 (allegedly the same as the eager beaver 2116) and discovered that all of the fuel lines had become cracked/brittle/broken. They look easy enough to replace, but from what's left of the existing ones, I can't tell where these things are supposed to go to and from. And the parts diagram I found isn't much help. Any one have an idea? Thanks in advance.
Old 10-10-07, 02:26 AM
puey61's Avatar
Received 2 Votes on 2 Posts
You'll have a total of three fuel lines associated with this saw. The line, in the tank, with the fuel filter attached goes to the fuel pump side fitting of the carburetor. The line, in the tank, that is about only an inch or so in the tank is the return line and originates at the "out" nipple of the primer bulb. And the third and last line goes from the "in" nipple of the primer bulb to the carburetor fitting furthest away from the fuel pump side. Note that the fuel pump side of the carburetor is the side that integrates the throttle idle speed screw.
Old 01-19-08, 02:04 PM
McCulloch fuel line routing
PUEY 61 is this the same routing for a 3516?
Thanks
Old 05-13-10, 05:50 AM
McCullogh 3200 chain saw fuel lines
I'm confused - Which side of the carburetor is the "fuel pump" side. Is it the side the adjusting screws are on? Have replaced all the lines, primer and rebuilt the carb but it will only run for a few seconds / choked.
