Honda 5.5 gas motor will only idle
jimb26's Avatar
OH
10-17-07, 06:29 AM   #1
Honda 5.5 gxs motor will only run with the choke on and then it will only idle if you try to rev it up it shuts down any Ideas
flopshot's Avatar
10-17-07, 06:43 AM   #2
fuel supply is restricted. clean main jet, check needle and float function, fuel filter and seperator.
jimb26's Avatar
OH
10-17-07, 06:48 AM   #3
thanks
Posted By: flopshot fuel supply is restricted. clean main jet, check needle and float function, fuel filter and seperator.
Thank you I'll give it a try
puey61's Avatar
NY
10-17-07, 11:52 AM   #4
You should have a fuel delivery problem, not a fuel supply problem. I'll bet cleaning the main jet will have it back running well but it certainly won't hurt to check the entire fuel system.
