Sears Presswasher
jsouth's Avatar
TX
11-06-07, 03:07 PM   #1
Sears Presswasher
I bought a used pressure washer at a garage sale,it did not come with the owner manual,I am trying to locate it on the web site,I found the parts break down in Sears parts but unable to download the manual.The pressure washer model# is 559-741720 SR.#0065363 and the part number for the manual is 5.951-894,Sears parts says the manual is unavible,I did a Google search with no luck.
Thanks
Jerry
GlenM's Avatar
OK
11-07-07, 06:38 AM   #2
My Sears Vendor Code list must be out date, I don't see a vendor code of 559, i.e. a code assigned by Sears to indicate the manufacturer or assembler of the product.
Are you having a problem with the engine or the pump?
Sears shows the engine to be a Briggs model 124702 type 0207, you can download the owners manual for it from the Briggs site
I would think the pump would have a Sears model number......
thanks,
jsouth's Avatar
TX
11-07-07, 11:44 AM   #3
No Glen the engine works fine,I put a gauage between the pump and the hose,and shows only 1000psi the pressure washer 1750 psi I check the hose and the wand,they are clear,the adjustment knob is all the way open,I thought the owner manual might give me some info on this.The water presure is ok at the house,because I used my neighbors pressure washer it work fine it is a craftman 2300psi.The engine runs smooth does not surge.
Jerry
GlenM's Avatar
OK
11-07-07, 12:07 PM   #4
Good, glad to hear it works. I was trying to find manufacturer of unit so's to get more info on who made the pump. but Sears says they have no record of vendor 559 which means it must be a vendor they haven't used for over 20 yrs., or they've been bot by someone else.
good luck,
thanks,
jsouth's Avatar
TX
11-07-07, 12:12 PM   #5
Thanks GlenM for your help,have a good day.
Jerry
