starter removal
Old 11-26-07, 04:03 PM
starter removal
How do I remove the starter on a Briggs and Straton engine on an 18hp Craftsman Riding Mower?
Old 11-26-07, 05:27 PM
Starter removal
It's not a hard job, usually just two bolts.
BE SURE to disconnect the battery before you start.
There's a gear on the end of the starter motor held on by a pin. Sometime the gear teeth break and the motor may still be ok.
Old 11-26-07, 05:29 PM
Is it a single piston or twin, the V cylinder OHV model, or the older opposed L-Head twin ??
I've removed several starters from the older opposed twins.
It's easier if shrouds/flywheel is removed, but, I've done it by removing the top and side shrouds and reaching in under the flywheel with a 1/2 box end wrench. It takes a while but is doable.
when reinstalling I thoroughly clean all threads of bolts and block with WD-40.
hope this helps,
if we had model, type and code of engine, would help.
thanks,
Trackbacks are On
Pingbacks are On
Refbacks are On
