Looking for engine Diagram
Old 12-05-07, 11:29 AM
daswede's Avatar
I have a new Ariens st 724E snowblower, mod 932046, Oh 195SA. Tecumseh snow-king OHV
I'm looking for a website that has a diagram of the engine,specifically,the Carb. Carbs are probably the most common problem with these machines so a diagram of r&r of the carb.would be a big help.
Thanks
Old 12-05-07, 05:02 PM
If you would post the numbers from the engine(usually found on the engine shroud above the spark plug) someone here can probably help. However, if you want to do it yourself go to the link below and download the manual. Have a good one. Geo
http://www.cpdonline.com/692509.pdf
Old 12-05-07, 05:20 PM
daswede's Avatar
Thanks geogrubb,
These are the only numbers other than what i posted before.
spec. 72560 G, DOM 06261ceo118,and ser# 015173
Old 12-06-07, 05:03 AM
Actually, since this is an OHV engine, the manual you need is the 2nd one, #695244a, at this site:
http://toprake.com/index.php?module=...position=11:11
For engine breakdown, enter OH195SA at this site:
http://www.landscapepower.com/tecumseh_partslists.html
go to end of page, the last spec listed here is 72549G, yours is 72560G, but is same basic engine series.
ref 380 in this list is carb 640058A
put this value in the model # box at
http://www3.sears.com/
and you can get an idea of the carb for this series,
hope this helps,
thanks,
Old 12-06-07, 05:24 AM
daswede's Avatar
Thanks glenm for taking the time get this info for me.
I found all the info i was looking for.
daswede
