Craftsman 9hp snow thrower
Old 12-15-07, 02:10 PM
Used 4 times last year and wont start this year. I did leave the gas in when stored. I drained the old gas and took the bowl off the carb. Took off float and pin and cleaned. Check fuel line to see if fluid was going fron tank to carb, it worked. Put everything back together and I still have the same problem. Primer only makes an air sound and the unit will not start. Did I miss some steps?
Old 12-15-07, 02:44 PM
Clean the bowl nut(main jet), I usually use the wire from a twist tie. Refer to the photo below. Have a good one. Geo
http://i190.photobucket.com/albums/z...c_bowl_nut.jpg
